"Text Mining in RM5"
ratheesan
In RM 4.6 I used Excel Example set Reader,Nominal to string and String text input to take the data in to RM from Excel sheet.Similarly which operators we can use to take excel data in to RM5 for Text mining.
Thanks
Ratheesan
Text Mining + NLP
land
this is really simple: The read excel operator does ... reading the excel file
Then you can use Nominal to Text operator to change the value type to text and use the process documents from data operator to do the text mining preprocessing part, that was former done by the StringTextInput.
Greetings,
Sebastian
ratheesan
Thanks Sebastian,
I worked with the above mentioned operators ,but always getting an error message "com.rapidminer.example.set.NonSpecialAttributesExampleSet cannot be cast to com.rapidminer.operator.text.Document"
Here I am attaching my process,Could you please point out my fault
<process version="5.0">
<context>
<input>
<location/>
</input>
<output>
<location/>
<location/>
</output>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<process expanded="true" height="314" width="762">
<operator activated="true" class="read_excel" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30">
<parameter key="excel_file" value="C:\Documents and Settings\GRACE\Desktop\1000.xls"/>
<operator activated="true" class="nominal_to_text" expanded="true" height="76" name="Nominal to Text" width="90" x="45" y="120"/>
<operator activated="true" class="text:process_documents" expanded="true" height="94" name="Process Documents" width="90" x="179" y="120">
<parameter key="vector_creation" value="Term Occurrences"/>
<process expanded="true">
<operator activated="true" class="text:tokenize" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/>
</process>
<operator activated="true" class="text:tokenize" expanded="true" height="60" name="Tokenize (2)" width="90" x="313" y="120"/>
<operator activated="true" class="text:filter_stopwords_english" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="447" y="120"/>
<operator activated="true" class="text:filter_by_length" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="581" y="120"/>
<connect from_op="Read Excel" from_port="output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="example set" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_port="result 1"/>
</process>
</process>
Thanks
Ratheesan
land
you have to put the text processing operators INTO the Process Documents operator. This is a super operator, that contains a subprocess. You can go there by double clicking on it.
Greetings,
Sebastian
ratheesan
I used the operators as you said,but then also I couldn't solve my problem ,Getting the same error.
This is my process.
<context>
<input/>
<output/>
<macros/>
</context>
<process expanded="true" height="284" width="762">
<list key="annotations"/>
<operator activated="true" class="nominal_to_text" expanded="true" height="76" name="Nominal to Text" width="90" x="180" y="30"/>
<operator activated="true" class="text:process_documents" expanded="true" height="94" name="Process Documents" width="90" x="315" y="30">
<operator activated="true" class="text:tokenize" expanded="true" height="60" name="Tokenize" width="90" x="39" y="96"/>
<operator activated="true" class="text:filter_stopwords_english" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="247" y="119"/>
<operator activated="true" class="text:filter_by_length" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="380" y="120"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Process Documents" from_port="example set" to_port="result 2"/>
<connect from_op="Process Documents" from_port="word list" to_port="result 1"/>
</process>
</process>
Thanks
Ratheesan
Andrew2
Hello Ratheesan,
Change the "Process Documents" operator to "Process Documents from Data"
regards
Andrew
