haddock wrote:Greetings!Motaz had a similar question, so this http://rapid-i.com/rapidforum/index.php/topic,1731.msg6958.html#msg6958 might be of interest.
haddock wrote:Hi there,Without seeing the data I can't be too helpful; however, the CSV reader is pretty reliable, so the answer probably lurks in the data. For instance, if your column separator parameter is the default setting then a misplaced space can screw things up, and so on.Good luck!
