<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="simple non linear classification"/> </operator> <operator name="NameBasedWeighting" class="NameBasedWeighting"> <list key="name_regex_to_weights"> <parameter key="att1" value="3.0"/> <parameter key="att2" value="2.0"/> <parameter key="att3" value="1.0"/> </list> <parameter key="default_weight" value="0.0"/> </operator> <operator name="WeightGuidedFeatureSelection" class="WeightGuidedFeatureSelection" expanded="yes"> <parameter key="show_population_plotter" value="true"/> <operator name="Xvalidation" class="XValidation" expanded="yes"> <parameter key="keep_example_set" value="true"/> <parameter key="sampling_type" value="shuffled sampling"/> <operator name="NeuralNetImproved" class="NeuralNetImproved"> <list key="hidden_layers"> </list> </operator> <operator name="OperatorChain (2)" class="OperatorChain" expanded="yes"> <operator name="ModelApplier (2)" class="ModelApplier"> <parameter key="keep_model" value="true"/> <list key="application_parameters"> </list> <parameter key="create_view" value="true"/> </operator> <operator name="Performance (2)" class="Performance"> <parameter key="keep_example_set" value="true"/> </operator> </operator> </operator> <operator name="ProcessLog" class="ProcessLog"> <list key="log"> <parameter key="File" value="operator.WeightGuidedFeatureSelection.parameter.use_absolute_weights"/> <parameter key="Performance" value="operator.Xvalidation.value.performance"/> <parameter key="Deviation" value="operator.Xvalidation.value.deviation"/> </list> <parameter key="sorting_dimension" value="3"/> </operator> </operator></operator>
