<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator" breakpoints="after"> <parameter key="target_function" value="polynomial classification"/> <parameter key="number_examples" value="1000"/> </operator> <operator name="ValueIterator" class="ValueIterator" expanded="yes"> <parameter key="attribute" value="label"/> <operator name="ExampleFilter" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="label = %{loop_value}"/> </operator> <operator name="AbsoluteSampling" class="AbsoluteSampling"> </operator> <operator name="Only do if already stored" class="ExceptionHandling" expanded="yes"> <operator name="Retrieve" class="IORetriever"> <parameter key="name" value="SetStorage"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="ExampleSetMerge" class="ExampleSetMerge"> </operator> </operator> <operator name="In every case: Store" class="IOStorer"> <parameter key="name" value="SetStorage"/> <parameter key="io_object" value="ExampleSet"/> </operator> </operator> <operator name="IOConsumer" class="IOConsumer"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="Final Retrieve" class="IORetriever"> <parameter key="name" value="SetStorage"/> <parameter key="io_object" value="ExampleSet"/> </operator></operator>
