Applying loads/constraints to sets
Fernando Hernández Alonso_20813
Altair Community Member
Hi there,
I would like to know if there is a way to apply loads or constraints to a set of elements (to avoid selecting the nodes when creating the force). It appears so, because in the menus of both constraints and forces it exist the possibility to select sets.
However, when I run the analysis, I get this error message: "Card "SPC" references incorrect SET type."
I attach the model I'm referring to. I would appreciate any kind of help.
Thank you in advance!
Best Answer
make sure your set has a 'SET_GRID' card image, ok?
0 -
Thank you so much, Adriano!
