<operator name="ExampleSetGenerator" class="ExampleSetGenerator">
<parameter key="target_function" value="random"/>
<parameter key="number_examples" value="10"/>
<operator name="ChangeAttributeRole" class="ChangeAttributeRole" activated="no">
<parameter key="name" value="label"/>
<operator name="CSVExampleSetWriter" class="CSVExampleSetWriter" breakpoints="before">
<parameter key="csv_file" value="check.csv"/>
<parameter key="column_separator" value=","/>
I want to write the data generated to a CSV file. While writing, the special attribute, 'label' is written as the last attribute in the CSV file, check.csv. But I need to write the data as the order appears in the Exampleset like (label,att1,att2,att3,att4,att5). Any hints on this?
Thanks and Regards,
Shubha
