I run the below code given in the sample XML files (04_NearestNeighbours.XML) for the KNN Classification.
<description text="This learner uses a simple nearest neighbors classifier. This instance based classifiers just uses the other instances closest to the instance at hand in order to determine a prediction."/>
<operator name="ArffExampleSource" class="ArffExampleSource">
<parameter key="data_file" value="../data/iris.arff"/>
<parameter key="label_attribute" value="class"/>
<operator name="NearestNeighbors" class="NearestNeighbors">
<parameter key="keep_example_set" value="true"/>
<parameter key="k" value="3"/>
But the result I get is a blank KNNClassification model with the contents,
KNNClassification
KNNClassification (prediction model for label class) |
and an id attribute added into the Exampleset.
Why are the results not displayed?
Thanks,
Shubha
