Is there any example documentation for UI Designer that I can refer to? I'm having trouble getting started. Thank you!
Hi @Robbert Lee,
There are different ways of using UI Designer. You have to keep in mind that once you generate the .OML code, you'll have to change the 'callback' functions to make the UI 'active'.
I'm attaching a package with Video + Model, showing how easy is using UI Designer.
