related I'm looking for a method to just subtract the mean without then dividing by the standard deviation.
<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="number_examples" value="200"/> <parameter key="target_function" value="sum classification"/> </operator> <operator name="FeatureNameFilter" class="FeatureNameFilter"> <parameter key="filter_special_features" value="true"/> <parameter key="skip_features_with_name" value="label"/> </operator> <operator name="ExampleSetTranspose" class="ExampleSetTranspose"> </operator> <operator name="AttributeAggregation" class="AttributeAggregation"> <parameter key="aggregation_attributes" value="att_.*"/> <parameter key="aggregation_function" value="average"/> <parameter key="attribute_name" value="mean"/> </operator> <operator name="FeatureIterator" class="FeatureIterator" expanded="yes"> <parameter key="filter" value="att_.*"/> <parameter key="work_on_input" value="false"/> <operator name="AttributeConstruction" class="AttributeConstruction"> <list key="function_descriptions"> <parameter key="mean_%{loop_feature}" value="%{loop_feature}-mean"/> </list> </operator> </operator> <operator name="AttributeFilter" class="AttributeFilter"> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="parameter_string" value="mean_.*"/> </operator> <operator name="ExampleSetTranspose (2)" class="ExampleSetTranspose"> </operator> <operator name="AttributeFilter (2)" class="AttributeFilter"> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="invert_filter" value="true"/> <parameter key="parameter_string" value="id"/> </operator></operator>
