command.cmf file is not getting updated
Akshay Manthekar
Altair Community Member
Hello all,
I am not finding command.cmf file in my working directory of hypermesh. I tried all options like unchecking "disable scripting", etc. Instead I am having "command.tcl" file in working dir and it is getting updated as I work in hypermesh. Can anybody tell how to get command.cmf file updated with hypermesh?
Thanks
This changed a few versions back. Command.cmf is no longer supported. The format for the "command file" is almost identical to TCL, so you can copy a block of text into a new file and add the parentheses and commas to make it into a CMF formatted block for use with the HM Utility Tab.
I hope that helps.
