Have you faced the following Managed License SSL error and are unsure how to fix it?
Error Code: 1
Error Description:
SOAP 1.1 fault SOAP-ENV:Client [no subcode]
"SSL_ERROR_SSL
error:14007086:SSL routines:CONNECT_CR_CERT:certificate verify failed
unable to get local issuer certificate"
Detail: SSL/TLS handshake failed
Please perform the following steps:
- Make sure you have installed all updates and are using the latest version of the product. The latest version is always available from the Marketplace.
- Work with your IT department to create an exception in your proxy for the traffic going to our servers on port 443 (https):
