Automated result math using HV and HVTrans
This video walks through the process of automating any derived results or result math that can be created in the expression builder. The example shows the creation of a derived result for factor of Safety or normalized stress by referencing an external file containing the material stress limits. The first step shows the manual setup in the expression builder. The second step is creating an xml file that encapsulates this information in from the first step. Finally we can run the process without needing to open HV using xml file in HVTrans. The attachments contains all the files used in this video.
Comments
No comments on this post.
