I have try to run the simulation but hyperview wont pop out or radioss block just show the job is completed
have you created the 'engine' keyworks to setup the run, itself?
you can use the search tool (Ctrl+F) and find the 'engine file assistant' to create your run settings and common outputs.
Also, there are some tutorials in the help for Radioss. it would be nice to check them.
