🎉Community Raffle - Win $25
Join and Win
SQL DB data source: Need to pull data by the previous calendar month
User: "michele_adamski"
Altair Community Member
Updated by michele_adamski
Hi all, I'm new to developing in Monarch and need a little help.
I need to create a report, pulling data from a SQL DB.
I’ve connected to the DB, located the correct tables and columns, and created the sort and saved the workspace.
However, I need to pull data by the previous calendar month and I don’t see an option to set a date by a variable. Is this something that can happen?
1 - 1 of 11
    User: "CPorthouse"
    Accepted Answer
    Updated by CPorthouse
    Are you looking to pull data from the previous 30 days or dates from the previous month?  For instance, if you take today's date 4/21/2021, do you need the data from 3/22-4/21/2021 or all days from March 2021?
    Either case, you will most likely need to use a query and a WHERE clause to get the data you are looking for.  To get the last 30 days you could add this to the end of the query statement that DPS generates:
    WHERE CreatedDateTime >= DATEADD(DAY,-30, GETDATE())
    The above says to get any row where CreatedDateTime is within the last 30 days.
