Using a compound filter I have identified duplicates within two list of data.
I want to remove those duplicate lines from another compound filter I have.
Is this possible to do using monarch?
I would take the formulas you used to create the individual filters and create a formula field that puts a yes/no value in the column that identifies the duplicates. You can then create another filter to filter out the yes values.
