I imported Motor geometry from CAD step file. I cut geometry to one electric period. I did geometry check its fine. But now if I try to build faced I get failed execution.
if I try to build volumes below is the error.
What is reason behind this?
Hi Snehal,
I guess this a 3D geometry can you confirm? . Usually when you import the CAD file in Flux 3D modeler it should have the faces and volumes on it and you just need to do the cut.
Also Flux doesn't allow any type of intersection in the geometry between any entities (points, lines , faces or volumes) so you have to make sure your geometry doesn't have any one of those.
Thanks,
