When I load a Step file, and press blank, there isn't any blank apart from the initial part itself. Do I have to create a separate flat blank sheet on top and bottom to continue the process? Or is this an error.
Hi,As mentioned Tryout process, I believe this ticket is for Inspire Form and not Inspire Studio.Also, as you mentioned when loading any file in the tryout interface, the workflow is to define a flat blank and then set the required operations such as Single action draw or double action draw. Refer to below link for more help, as it shows the complete tryout process setup and the components required for tryout setup.https://help.altair.com/form/en_us/topics/form/tutorials/tut_tryout_sad_basic_c.htm#concept_rdx_vvc_tdbThanks.
