Is there somewhere a setting, where I can limit how much joint (hinge for example) can rotate? I don't want to add contact graphics for that, because it is heavy, so can I limit some how like -90 deg - +90 deg? Maybe some kind of end dampers?
Same thing with the springs, why there is no end dampers in the springs? There is setting "Penetration Depth" but for what and where it starts?
