I'm getting a volume mesh failure in Hyperworks CFD, caused by "Warning: 1 nodes found to have bad topo."
I assume this is the node ID: "n1203618(ni177756)"
Is it possible to find and fix the node which is causing this "10 elems resulted in invalid cfgs due to node collapsing. (has error highlighted)10 elems failed and saved."?
And if not is there another method to fix the issue?
Log file attached
Thanks!
