Hi Support Team,
 I have developed script to create Note for element ID and contour value. I have drawn with Clinet handle, but note is not appearing on the Hyperview window. Once I click create new note manually in Note Tab it will show but through script note is not apperaing. Can please look into this issue. I have attached script for your reference.
 set t [::post::GetT];
 set note_id [elAvg$Wn AddNote]
 set n_handle [elAvg$Wn GetNoteHandle noteH$Wn $note_id]
 noteH$Wn SetAttachment "element $model_id $maxElemID"
 noteH$Wn SetPositionToAttachment true
 noteH$Wn SetPosition right
 noteH$Wn SetPosition top
 noteH$Wn SetPosition 1 1
 noteH$Wn SetBorderThickness 1
 noteH$Wn SetLabel "Max Contour value"
 #noteH$Wn SetText "NodeID {entity.id} \nContour_Value {entity.contour_val}"
 noteH$Wn SetText "Element ID $maxElemID \n Contour Value $ElemVal";
 #elAvg$Wn Draw
 noteH$Wn SetAlignment "left"
 noteH$Wn SetTextColor "255 255 255"
 noteH$Wn SetBackgroundColor "0 0 0"
 noteH$Wn SetScreenAnchor false;
 noteH$Wn SetTransparency true;
 noteH$Wn SetVisibility true;
 elAvg$Wn Draw;
