multi-material topography optimization
Hello everyone,
I have 2 questions:
1. is it possible to apply a Topography Optimization also for 3D Model or this is only for 2D Models.
2. is a multi-material topography optimization also feasible for Optistruct? If so, is there an example somewhere?
Thank you for your help
Best Answer
Hi Reza Karshenas,
Below is the answer for your questions.
1. It is possible to do Topography optimization for 3D models provided you need to have a shell element layer around the solid which need be considered in DTPG card as design variable. You can follow the below example for reference.
OS-E: 3035 Surface Optimization of a Control Arm (altair.com)
2. Usually, Multi material Optimization is preferred for Topology Optimization.
Thanks....
Hi Reza Karshenas,
Thanks....
