Hello
One thing I couldn't find in the manual is how to mesh different objects with different triangle edge lengths?
What I am trying to do is mesh different objects differently because I have some large cubes that don't need a very fine mesh
but I also have some cubes that are very small that need a much smaller mesh size
What I am trying to do is something like this based on a previous post:
-- for loop that will create many cubes here base on index i
temp_cube = project.Geometry:AddCuboid(cf.Point(x_pos_list, y_pos_list, 0), length_, length_, length_)
MeshSettings = project.Mesher.Settings
properties_m = MeshSettings:GetProperties()
properties_m.MeshSizeOption = cf.Enums.MeshSizeOptionEnum.Custom
properties_m.TriangleEdgeLength = SOME_STRING_BASED_ON_CUBE_SIZE -- ex: '0.1' or '0.2', etc
MeshSettings:SetProperties(properties_m)
project.Mesher:Mesh(temp_cube)
-- end of for loop
where the last command project.Mesher:Mesh(temp_cube) only meshes the temp_cube in question and doesn't mesh any other objects
also I have access to the cube number in this loop in case that is useful
