I have multiple components in my model. I use the auto contact feature to generate set segments for contact. Now I want to have a thin layer of shells near the contacts. How do I generate faces only on the elements which are in contact?
If I directly use faces command, it generates it on the whole body. Is there a quick way to generate faces from set segments or contact surfaces?
Thanks,
Akhilesh
