I've been trying to introduce eccentricity in my SynRM motor. I found a way using an Altair example (KB0120301), which initially ran successfully. However, the example is based on a permanent magnet motor that has 5 poles and 10 magnets.
 To adapt the macro to SynRM, I used FluxMotor to create the motor and then attempted to export it to Flux. Unfortunately, this was unsuccessful with both 4-pole and 10-pole configurations, as FluxMotor does not support the 5-pole configuration similar used in the example. When comparing the exported file to the sample motor, I noticed that the poles were not exported correctly. I understand that the flux barriers in the SynRM are causing issues with the geometry and coordinates. Is there a way to modify the macro or the export process to make it compatible with my SynRM motor?
 When applying the macro I always get this type of error when applying to motors that was exported from FluxMotor to Flux.
