🎉Community Raffle - Win $25
Join and Win
How do I get the initial value of a parameter in a javascript part
User: "Tony Halse_22248"
Altair Community Member
Updated by Tony Halse_22248
I can listen for parameter changes in the PostLink section of a javascript part using code like the snippet I've pasted below.
But I want to find the initial value of a parameter as well (ie the value on entry to the dashboard, before it is ever changed).
Is there a function I can call to retrieve this value?
config.handleParamChanged = function h(event) {
 var v = event.parameters.filter(function (param) {
  return param.name === 'maxrows';
 })[0];
 if (!v) {  return; };
  config.maxrows = v.value
PanopticonApi.addParameterListener(config.handleParamChanged);
function destroy() {
    PanopticonApi.removeParameterListener(config.handleParamChanged);
return destroy;
1 - 1 of 11
    User: "Mikael Konradsson"
    Updated by Mikael Konradsson
    Sorry for the late reply!
    Have a look at the function PanopticonApi.getCurrentWorkbook(). This function will return the current state of the workbook.
    With Regards
    Mikael
