How do I solve axial flux machines with dual rotors and single-coreless stator circuit formulation issues?
I initially used the same circuit used for macro but it didn't work and I built my circuit for a 3-phase system with, same issues
Hi Isakia,
Firstly if you have message related to formulation and circuit, you can firstly checked that the coil conductor circuit component in the circuit is linked to the FE domain. I mean by this that a coil conductor region or a non meshed coil is linked to your coil conductor circuit component.
Could you check this point?
Best regards.
Cyril
Solved
