I am trying to calibrate stiffness and damping parameters in a complex eigenvalue analysis with Hyperstudy. However, there is a warning message when evaluating the damped natural frequency using readmac function (similar to tutorial HS-4410):
"The Datatype "Eigen Mode (Grids)" does not have all components "Time,X,Y,Z,MAG".
Please check if you are using correct datatype"
It works with normal modes analysis, but is complex eigenvalue analysis also supported with this function? It is possible to extract undamped natural frequency from the out file, but not damped natural frequency. Is there any workaround?
The relevant files are attached if someone would kindly look into it.
