I would like to generate the monopole antenna array and distance between the elements is lambda/2 i.e. 0.5 spacing. When I use copy, translate and duplicate options the monopole antennas with their base coupled with each other and looks like mess. what is the solution to create antenna array with 0.5 spacing between them. Help could be appreciated.
