When I run this command using below tcl
hv -b -tcl Image_Capture1.tcl example.modl example.res
This is the results log I see on my linux terminal:
Ready
Loading Report...
Applying Report...
Ready
Ready
Capturing...
Ready
It's stuck at 'Ready' and unless I press Ctrl+c or enter it doesn't exit back to terminal. How can I make the code to exit to terminal after the proc is over?
proc BatchMain { } { set inputdeck [lindex $::argv 6] set resultfile [lindex $::argv 7] puts $inputdeck puts $resultfile set t [::post::GetT] hwi GetSessionHandle sess$t sess$t GetProjectHandle proj$t hwi OpenStack sess$t LoadReport Batch_Process.tpl sess$t ApplyReport Batch_Process replace true false 2 $inputdeck $resultfile set numpages [proj$t GetNumberOfPages]; for {set i 1} {$i <= $numpages} {incr i} { proj$t SetActivePage $i proj$t GetPageHandle pg$t $i pg$t Draw pg$t ReleaseHandle sess$t CaptureScreen png image_$i.png } hwi CloseStack proj$t ReleaseHandle sess$t Close } BatchMain
