Hi
I am doing a nonlinear direct transient analysis.
1. i have done a bolt preload analysis .
2. The Bolt preload case is called in to the nonlinear direct transient analysis.
In the bolt preload step suppose if bolt is compressed by 1 mm, it shou;ld be compressed by 1 mm at the beginning of loadcase 2 , Yes it is happening.But gradually as the load case progresses, the bolt is comimng to its initial length , which means , the preload is getting nullified in the second load case .
My problem is , Once the bolt is pretensioned , it should remain pretensioned in the second load case also.
Please help me in this regard ...
This is very urgent and important ...
