Altair RISE
Nominate Yourself Now!
Visualization error in review element orientations pannel
User: "Rafal Blasczykowski"
Altair Community Member
Updated by Rafal Blasczykowski
Hello!
It seems to be a visualization error in Hypermesh 2023.1, in review element orientations pannel, because, v. gr. in a simple meshed plate (with edges paralell to x-y), when "Elemental system" is chosen and the elements are picked, elemental axes are aligned with global axes. But if the plate is rotated, e. g. around z-axis, if "Elemental system" is chosen and the elements are picked, the elemental axes are the same as before, oriented with global axes. But this is wrong. If "orientation" is selected and an orientation change is tried, the elemental axes do not change (at least in visualization, but maybe in the back they do).
Has someone test this?
1 - 1 of 11
    User: "Jason_Craanen"
    Updated by Jason_Craanen
    I do not see an issue. Perhaps you can verify you have only rotated the plate and not reoriented the elements as well?
