When using the HM subsystem browser to reconfigure my overall model I don't understand why clicking on a configuration effects both the "active" and "export" states of all the parts/components but only effects the "active" state of items such as loads, groups (contacts), rigid body joins, sets, etc (essentially anything other than geometry/mesh)?
In other words when I select a new configuration from the subsystem browser it changes these effected items "active" state but does not switch the "export" state. Therefore I have to manually change the export state of each of these items to match the active state before I export the deck.
Why can't the behaviour of these items be the same as the part/component items where both states are switched at once?
If this was the case then a total model reconfiguration would be possible with a single click of the particular configuration required in the subsystem browser?
Is this behaviour possible to change or am i missing something here as to why this isn't already the case?
Thanks.
Richard.
