Hi, I'm doing for my Master Thesis a Topology Optimization of a component using solid Tetra elements. As constrints I put volume fraction and the wheighted compliance as an objective. I'm also using 6 loadsteps simultaneously. Is there a way to get the stress map directly on the optimized part or I need to do another static analysis with the new geometry? Is there a control card I can activate to obtain this result?
Tank you
