data import/export context for flux skew
Divin Pulakudiyil  Xavier
Divin Pulakudiyil Xavier Altair Community Member
edited June 2023 in Community Q&A
Hi All,
Are there any documentation about force computation & data import/export context with Altair flux skew (2022.3)?
Because I tried this and got 0(N)
And the same model with 'integral on line' -->lines associated with region --> stator region and selecting the line gave me some values
  • fzidat
    fzidat
    edited May 2023
    Hello Divin,
    It is supposed to be like a 3D post processing, what is the computation you want to do, are you using Mechanical coupling or Generic one ?
    Regards
  • fzidat
    fzidat
    edited May 2023
    The workflow to compute magnetic forces is explain in the following video:
    Magnetic force computation in IPMSM using Altair Flux - YouTube
    only thing to consider is that in 2D the support is supposed to be created on lines or imported, in 3D, the support  is supposed to be created on faces or imported.
    Regards
  • Divin Pulakudiyil  Xavier
    edited June 2023
    Hello Farid,
    Thanks a lot for the video
    Since it is like 3D, You meant the documentation for data import/export contex for skew would be the same as 3D right?...
    I have not tried flux 3D yet but, I was a bit confused because under computation region option there where face and volume region in skew and I could not find any documents specifically for Skew.
    Thanks
    Divin
  • fzidat
    fzidat
    edited June 2023
    Hi Davin;
    You are welcome!
    Yes, and normally for the forces, you need to select faces to create your support, this support can be also imported, you don't need to select face regions or volume regions
    Once you created the support, you can then collect data on it, here you want to compute the magnetic forces
    The workflow is always the same in 2D Skew or 3D
    Magnetic forces computation and export in Flux (altair.com)
    I hope this will help you
    Regards
