I have a code creating particles varying in size and am currently using the scale function in "createParticle" under the EDEM factory API to do so. However, I realize that some of my smaller particles (scale < 1e-3, diameter < 1e-3mm) are not being created. However, when I increase their scale, they are able to be successfully created.
As such, may I find out if there is a minimum scale/diameter for a particle to be created using the EDEM API factory? And if so, what is the minimum value?
Megan
