I'm doing a CFD simulation in hypermesh (Acusolve) and then post-processing in hyperview. Its a internal flow and I want to animate to analyse how the flow is behaving. It's possible to do it?
Thanks
Assuming that you have run a transient analysis, you can animate it using the 'transient mode' animation. It will loop through all youtr timesteps.
Are you using this?
This will also depend on having requested multiple output sets to be written, for example every 5 time steps, in the AcuSolve .inp before running the solver.
