Need to add near-field script to existing POSTFEKO session using Lua
John Underwood
John Underwood Altair Community Member
edited December 2022 in Community Q&A
I am trying to add near-field scripts in POSTFEKO using Lua to dynamically generate them.
According to the API reference, I need to do the following:
nearFieldMathScript = app.MathScripts:Add(pf.Enums.MathScriptTypeEnum.NearField)
My problem is with "app".
When I try to use "app = pf.GetApplication()" to define the variable, I get the following error:
".. attempt to index global 'app' (a nil value)"
Any ideas?
Thanks in advance
Welcome!
  • Torben Voigt
    Torben Voigt
    Hi @John Underwood ,
    What exactly is the goal of the script? Creating near field requests would only be possible in CADFEKO. Are you sure you mean POSTFEKO?
    Best regards,
    Torben Voigt
  • John Underwood
    I need to process existing displayed near-field data with math scripts and would like to create these math scripts with a single custom script since there are many of them.
    Correct me if I am wrong but I think the fact that "app = pf.GetApplication()" does not work when in POSTFEKO is a major issue. I have tried the script examples in the guide and none of them work because of this.
    Your help is appreciated in this matter.
    Thanks
  • Torben Voigt
    Torben Voigt
    I just tested just these 2 lines in POSTFEKO:
    No error, "NearfieldMath1" is created.
    Could you maybe attach your script here?
    Best regards,
    Torben
  • John Underwood
    Hi Torben,
    I have figured out what the problem is.
    I was trying to perform the task using a "Custom" script under the "New Script" menu instead of running it as an external script.
    The script user document is not clear on this. I stumbled upon it when I clicked on "New" in the script editor.
    **** Just found in the script document (under "General Scripts") where the above is explained. ***
    Thanks for your help.
    John
Welcome!
Welcome!
