🎉Community Raffle - Win $25
Join and Win
Errors generated after Importing geomentry
User: "Jagan"
Altair Community Member
Updated by Jagan
I imported a housing + shroud geometry in (.stp) format. fin tip and shroud has a clearance of .0007m as shown
But in hyperworks cfd the fin tip and shrorud turned out to be merged and its generating solid errors and sometimes surface errors.
Please Help, thank you!
1 - 3 of 31
    User: "acupro"
    Updated by acupro
    Does it make any difference if you set the tolerance (click on the three-bar/hamburger icon) to a lower value - 1.e-5 or 1.e-6 then do the checks?
    User: "Jagan"
    OP
    Updated by Jagan
    The clearance is present if I open the .stp model on any other cad software but its intersecting in hyperworks.
    User: "acupro"
    Updated by acupro
    What happens if you modify the cleanup tolerance before import?
    Before you click the final 'Import' button - go into the Topology area where you can set 'Cleanup Tolerance' to 'Manual' and enter a value - say, 1.e-6.
    (You can also get there from File > Preferences > HyperMesh (Geometry) > Import Options - then go into STEP > Topology)
    Does that make any difference?
