Hi, I'm trying to perform a topology optimization on a defined solid element volume, already tried making bigger and smaller elements, changed the Load formulation, changed the SPC, played around with the optimization parameters, with minsize and max size too, have tried everything but I'm only getting spheres around the SPC and Load points and it always says the solution has converged and it met all the constraints placed. Can someone help me how to make the solver stop doing this and propose a real geometry?
Attached is a picture of the result and the model if someone can check it out and tell me where is my mistake
