I am trying to produce PWM signal with variable frequency but when ı click to start simulation, PSIM gives the warning in the picture. How can I solve this problem ?
Dear User,
In your attached image, I see that the code-generation related blocks are all greyed out, thus disabled. If you have the code generation features in your PSIM license, you should be able to activate them by navigating to:
Options -> License Setup -> Check "Code Gen" feature -> Authorize & OK
Best regards,
Nikos Dimitrakopoulos
