I'm currently working on a EMC simulation using Feko MTL/Cables simulations. The system must account for the presence of a LISN device, upon which a voltage is supposed to be read through the a load present at a cable port at the adequate place in the circuit. The circuit is currently configured as such:
** Note that I'm only interested in reading the voltage at Pin_L1. Pin_N does not need to be evaluated **
There's a 50 ohm load at the port VL, as expected:
In theory, I see no reason as to why this shouldn't work. However, upon saving the model before running the solver, the software crashes and presents the following messages:
Unfortunately, I can't seem to understand the error message and the problem with the schematic. I'm particularly frustrated because a regular 50 ohm resistor could be used instead of the loaded cable port, but that would make my analysis much more complicated since probed voltages/currents in circuit elements do not get stored as stored sweep data in the paramatric sweep application macro - which I intend to make use of.
Could anyone please indicate why this error occurs and, naturally, how to solve it?
Thanks for your attention!
