Hi all.
i made some hypermesh macros in form of 'toolbar'
if you feel it interesting, please send me your mcid /emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
Congratulations,it really looks so interesting /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
Interesting! But if you could share us how to do that, it's even more interesting /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
Interesting! But if you could share us how to do that, it's even more interesting /emoticons/default_smile.png' alt=':)' srcset='<fileStore.core_Emoticons>/emoticons/smile@2x.png 2x' width='20' height='20'>
Hiii Mr.Quy
to measure (diameter, surf-surf distance, ...) => click on corresponding toolbar buttons
pick a circle => it shows diameter and radius
pick 2 surfs => it shows distance
pick a surf then a line => it shows distance,
i add options to measure distance at closest position or picking position (ex. if in case 2 surfs or surf-line are not parallel)
No, I'm speaking about ... TCL script, not its usage /emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
/emoticons/default_biggrin.png' alt=':D' srcset='/emoticons/biggrin@2x.png 2x' width='20' height='20'> it's a secret!
i'll give a brief explain (actually difficult to explain fully in english, i am sorry)
- diameter measure: i used only command hm_getbestcircle, it return diameter value directly just in one click
- surf-surf measure: when click on surf, it creates a node at clicking position, the node then projected to alternative surf, projecting direction is not normal to the surf but make equally angle with each surf (so in case 2 surfs not parallel then => get correct distance)
- surf-line measure: similar to surf-surf, but temp node will be created on line, it then projected normally to surf (to find normal distance) and hm_getdistancefromnearest on surf to get true distance
- line-line measure: similar to surf-surf, but after temp node created on a line, a closest position from it on the alternative line will be get (hm_getdistancefromnearest)
- segment-segment (used when measuring height of a bead): i do some vector operations to find common perpendicular line of the two segment, length of it is distance between 2 segments, with option 'extended closest postion' then this value is reported, in case of 'closest position' it is compared to relative position between 2 segments ( as edge-to-edge contact calculation)
Thank you!
I'm looking for a sample code to create a customized toolbar like yours. I searched within HM's documents but I found nothing for this moment /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
Hii Mr.Quy
below is code to make my toolbar
actually create toolbar can be done as in 'hmsettings.tcl' file. but i modify something to fix errors when starting hm or first invoking to the functions
/emoticons/default_cool.png' alt='B)'>
proc ::nvtb:_DestroyToolBar {ToolBarName} { if {[winfo exists ._ViviToolBar-$ToolBarName]} { destroy ._ViviToolBar-$ToolBarName } foreach window [winfo children .] { if {[string match *.minibartoplevel* $window]} { foreach window2 [winfo children $window] { if {[string match *ViviToolBar-$ToolBarName* $window2]} { destroy $window break } } } } } proc ::nvtb:_CreateMeasurementToolBar {} { ::HM_Framework:_CreateMinibar . ViviToolBar-Measurement HyperMesh:HyperMesh:_blank ::HM_Framework:_SetMinibarIconList ViviToolBar-Measurement [list \ [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureCircleDiameter-24.png ] 'if {!\[namespace exists ::nvtb\]} {source \'$::nvtb::v_InfoScript\'; ::nvtb:_MeasureCircleDiameter } else {::nvtb:_MeasureCircleDiameter }' {Circle Diameter} 1] ] \ [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureDistanceSurfSurf-24.png ] 'if {!\[namespace exists ::nvtb\]} {source \'$::nvtb::v_InfoScript\'; ::nvtb:_MeasureDistanceSurfSurf } else {::nvtb:_MeasureDistanceSurfSurf }' {Surf-Surf Distance} 1] ] \ [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureDistanceSurfLine-24.png ] 'if {!\[namespace exists ::nvtb\]} {source \'$::nvtb::v_InfoScript\'; ::nvtb:_MeasureDistanceSurfLine } else {::nvtb:_MeasureDistanceSurfLine }' {Surf-Line Distance} 1] ] \ [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureDistanceLineLine-24.png ] 'if {!\[namespace exists ::nvtb\]} {source \'$::nvtb::v_InfoScript\'; ::nvtb:_MeasureDistanceLineLine } else {::nvtb:_MeasureDistanceLineLine }' {Line-Line Distance} 1] ] \ [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureDistanceSegmSegm-24.png ] 'if {!\[namespace exists ::nvtb\]} {source \'$::nvtb::v_InfoScript\'; ::nvtb:_MeasureDistanceSegmSegm } else {::nvtb:_MeasureDistanceSegmSegm }' {Segment-Segment Distance} 1] ] \ [list [list p_CreateMinibarIcon options-24.png 'if {!\[namespace exists ::nvtb\]} {source \'$::nvtb::v_InfoScript\'; ::nvtb:_Options } else {::nvtb:_Options }' {Options} 1 ] ] \ ] ::HM_Framework:_AddMinibarToDockframe ViviToolBar-Measurement .mainFrame.dockframe_top set ::HM_Framework::Minibar::ViviToolBar-Measurement:_status 1 } proc ::nvtb:_CreatePullDownMenuForToolBar {ToolBarName} { #set menu [. cget -menu].view.toolbars set menu [hm_framework getpulldowns].view.toolbars if {[catch {$menu index ViviToolBar-${ToolBarName}}]} { $menu add checkbutton \ -indicatoron 1 \ -offvalue 0 \ -onvalue 1 \ -variable ::HM_Framework::Minibar::ViviToolBar-${ToolBarName}:_status \ -command '::HM_Framework:_ToggleMinibar ViviToolBar-${ToolBarName}' \ -label ViviToolBar-${ToolBarName} \ -underline 0 return 0 } else { return 1 } }
Hi tinh,
Thank you so much for sharing it with us /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
Thank you so much Tinh!
Hi.. Would you please send me the code.. suresh.babuks@gmail.com
Thanks for sharing.. Is this the complete code??
Hi, below is complete code, after some persons used, i fix some bugs
now already 4 persons use it /emoticons/default_biggrin.png' alt=':D' srcset='/emoticons/biggrin@2x.png 2x' width='20' height='20'>
If you like, please send me your MCID, i just want to record number of users
What is the MCID?
and when i try to run this script it is also saying 'COULD NOT VERIFY MCID'.
What should i do?
Reg
Karthi
Hi tinh, What is the MCID? and when i try to run this script it is also saying 'COULD NOT VERIFY MCID'. What should i do? Reg Karthi
Really? Could you try again with this new updated:
I tried with the updated one also.. It is also coming same
Unexpected Error
Could not verify your MCID. Please contact to tinh411@gmail.com
Hi all
this second toolbar has auto-detect mesh features and help fast create some element patterns with less picking
/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' width='20'>
i finished set of 3 toolbars. Hope new hypermesh version will have new nicelooking ones /emoticons/default_cool.png'>
It is throwing Error while executing this script in Hyperworks 12.0
Can you please help me on this .I am trying to call the tcl file which was provided in the zip file
Regards
sri
It is throwing Error while executing this script in Hyperworks 12.0 Can you please help me on this .I am trying to call the tcl file which was provided in the zip file Regards sri Hi, could you please inform me what error occurred? input below command at command window to know detail set errorInfo
set errorInfo
can you please share the macro as tcl file
#created#varthamananproc CreateToolBar { carName jataList } { #Create Toolbar ::HM_Framework:/emoticons/default_tongue.png' alt=':P' srcset='/emoticons/tongue@2x.png 2x' width='20' height='20'>_CreateMinibar . $carName; #Add Icon foreach Data $jataList { set iconfile [ lindex $Data 2 ] set cmd [ lindex $Data 1 ] set name [ lindex $Data 0 ] ::HM_Framework:/emoticons/default_tongue.png' alt=':P' srcset='/emoticons/tongue@2x.png 2x' width='20' height='20'>_AddIconToMinibar $carName \ [ list p_CreateMinibarIcon [ file tail $iconfile ] $cmd $name 1 ]; } #Pack Toolbar ::HM_Framework:/emoticons/default_tongue.png' alt=':P' srcset='/emoticons/tongue@2x.png 2x' width='20' height='20'>_AddMinibarToDockframe $carName .dockframe_center; #Destroy}proc RedrawWindows { } { set pos [ hm_getcommandposition ] if { $pos == 'top' } { hm_setcommandposition bottom hm_setcommandposition top } else { hm_setcommandposition top hm_setcommandposition bottom }}set jataList ''# quick edit panelset EditIcon 'nodesInterpolateOnSurf-24.gif'set jataList '$jataList { {Quick Edit} { ::face {args} } $EditIcon }'# automesh panelset MeshIcon 'meshLines-32.gif'set jataList '$jataList { {AutoMesh} { hm_pushpanel \'automesh\' } $MeshIcon }'# check panelset CheckIcon 'check.gif'set jataList '$jataList { {Element Checks} { hm_pushpanel \'check elems\' } $CheckIcon }'## vis buttonset MeshIcon 'distanceBetweenNodes-24.gif'set jataList '$jataList { {Distance} { hm_pushpanel \'distance\' } $MeshIcon }'## vis buttonset MeshIcon 'edgesGeneral-24.gif'set jataList '$jataList { {Edges} { hm_pushpanel \'edges\' } $MeshIcon }'# vis buttonset MeshIcon 'elem-normal.gif'set jataList '$jataList { {Normals} { hm_pushpanel \'normals\' } $MeshIcon }'# vis buttonset MeshIcon 'intersectionGUI.gif'set jataList '$jataList { {intersection} { hm_pushpanel \'penetration\' } $MeshIcon }'# vis buttonset MeshIcon 'numbers-24.gif'set jataList '$jataList { {Numbers} { hm_pushpanel \'numbers\' } $MeshIcon }'# vis buttonset MeshIcon 'pan.gif'set jataList '$jataList { {Translate} { hm_pushpanel \'translate\' } $MeshIcon }'# vis buttonset MeshIcon 'pointsExtractParametric-24.gif'set jataList '$jataList { {Project} { hm_pushpanel \'project\' } $MeshIcon }'# vis buttonset MeshIcon 'blankNesting-24.gif'set jataList '$jataList { {Reflect} { hm_pushpanel \'reflect\' } $MeshIcon }'# vis buttonset MeshIcon 'gap-24.gif'set jataList '$jataList { {Replace} { hm_pushpanel \'replace\' } $MeshIcon }'# vis buttonset MeshIcon 'erase-16.gif'set jataList '$jataList { {Edit elements} { hm_pushpanel \'edit element\' } $MeshIcon }'# vis buttonset MeshIcon 'objectives.gif'set jataList '$jataList { {Replace} { hm_pushpanel \'split\' } $MeshIcon }'## vis buttonset MeshIcon 'linesExtractEdge-24.gif'set jataList '$jataList { {Smooth} { hm_pushpanel \'smooth\' } $MeshIcon }'## vis buttonset MeshIcon 'linesOffsetConstant-24.gif'set jataList '$jataList { {node edit} { hm_pushpanel \'node edit\' } $MeshIcon }'## vis buttonset MeshIcon 'post-shaded-16.gif'set jataList '$jataList { {node edit} { hm_pushpanel \'ruled\' } $MeshIcon }'## vis buttonset MeshIcon '3dElements-24.gif'set jataList '$jataList { {node edit} { hm_pushpanel \'drag\' } $MeshIcon }'## vis buttonset MeshIcon 'solidDragLine-24.gif'set jataList '$jataList { {node edit} { hm_pushpanel \'solid map\' } $MeshIcon }'## vis buttonset MeshIcon 'morphingVolume-16.gif'set jataList '$jataList { {node edit} { hm_pushpanel \'HyperMorph\' } $MeshIcon }'proc ::face {args} {*appendmark elements 1 'by adjacent'hm_saveusermark elems 1;*appendmark elements 1 'retrieve'hm_highlightmark elems 1 h;}# create toolbarcatch { ::HM_Framework:/emoticons/default_tongue.png' alt=':P' srcset='/emoticons/tongue@2x.png 2x' width='20' height='20'>_DeleteMinibar CustomToolBar }CreateToolBar fanels $jataList# redraw windowRedrawWindows
this is my toolbar created by most using command
Hi tinh, could you please share this macro with me? It looks very interesting. Do you know if it works with hypermesh 2017? Thank you in advance
I am eagerly waiting for this toolbar script.
could you please share this macro with me? It looks very interesting.Thank you in advance
Forget it! Hm2019 toolbars are really nice and convienience.
Hello Tinh,
I am really happy for your response.
Hm 2019 toolbars may be better but we still using old version like hm 14 and hm 17 as stable versions.
Kindly share with us it will be more and more useful. Rather than keeping them calm, we wanted to use it fully and efficiently.
Hope you help us with your scripts.
here my mail id to drop it ravinderdme@gmail.com
Thank you in advance!
