I am currently on the verge of completing, ' Learn pre processing with Hypermesh Part- 1'. But I am stuck at the last exercise of 2D shell meshing and topology refinement.
I am able to successfully load the 2D model and do the automesh. But the edit parameters window is not opening in the auto cleanup interaction menu.
I get an error message
I tried closing and reopening the model, used a different model and I even tried restarting the computer. None of these worked.
I tried reinstalling Hyperworks. It worked for the first time when I opened the model. But after I closed the application and tried again, it stopped working.
Can you please help me with this issue?
