Running into an issue when trying to extrude a line into a surface. I'm trying to extrude the line using Node 1 and Node 2 as refence points for both the directional data, and for the length of the extrusion, similar to what could be accomplished in the classic hypermesh GUI
 1) Select the line
 2) Reposition Vector tool
 3) Realign vector tool from Node1-to-Node2
  After hitting ENTER or the middle mouse button the vector tool just stays there, and I'm never able to proceed with the extrusion
