I am trying to run Flux on Linux. but it keeps flashing out when start a new project. so I wonder that is a license valid for both Windows and Linux version? shall I get a new license for the Linux version?
The license works independently of the platform,you don't need a separate license. You should check the environment variable.
Thanks, Hakan
I believe I am in BASH shell. Maybe a stupid question as I am new for Linux. The flashing out is because of the license_path undefined?
Hello Wenjun,
Were you able to run Flux in Linux. Or do you still have the issue?
Thank you,
Lavanya
Hello Wenjun, Were you able to run Flux in Linux. Or do you still have the issue? Thank you, Lavanya
Sadly,no... I can open the supervisor, but when I start a new project, it will flash out, even through the license path is defined.
Which version are you using?
Please send a copy of environmental variables defined.
Which version are you using? Please send a copy of environmental variables defined.
may I have your email to keep the info private?
I have sent an email to you. Please reply to that email.
