Hi
I am new to the Altair WinProp, and I was trying to generate antenna pattern using the generate beams and envelope pattern. I kept the default values as it is. Then I generated and saved the file with extension .ffe. When I checked the directory I save the file in, the file was not found. I have repeated theis several times with different directories. The way I did that is by opening the AMan, then from file I chose generate beams and envelope pattern. Then, I clicked on generate to save the file. There is no errors and it seems the saving was successful. Note, I am using the "Student Edition".
Any suggestions would be appreciated
Thanks
Ahmed
