Hi all experts,
Can you explain for me the difference between 3 terms?
Thanks all.
Hi Nancy,
The Set Type defines the way your set have been created and the importance of the nodes. It works as a flag. More precisely the different formulations shown in the image you shared refer to the following descriptions:
For the majority of the applications (most of the /INTER, /BCS and Loads) the non-ordered Set Type selection works fine.
Polyvios
Hello Polyvios,
How can I create a range in Hypermesh? It will be helpful if you can share the steps or even if you can share the Radioss deck screen shot of range, we can edit in text editor.
Naresh Kini
Hello Polyvios, How can I create a range in Hypermesh? It will be helpful if you can share the steps or even if you can share the Radioss deck screen shot of range, we can edit in text editor. Regards, Naresh Kini
Hi Naresh,
In the following KB you can find the steps in order to create a set with items in a specific range of IDs.
https://community.altair.com/community/en/how-to-create-a-set-through-formula?sys_kb_id=10a89ea1db8fbd50cfd5f6a4e2961990&id=kb_article_view&sysparm_rank=1&sysparm_tsqueryId=fb7b72171b8a8218c4dfdbd9dc4bcb6f
