Hello
I used the example of the software itself to measure the speed of a motor with IC 28335
But the results of the practical test were as follows?
What is the reason for this problem?
Hi, Reza,
Please check your practical test setup. Does your motor run in a steady speed?
What are the waveforms of A and B from your encoder?
Do those signals have the same waveform (frequency, shape, and phase) as the simulation result?
