Problem with MathExpressionBlock
Aiko
Altair Community Member
i have a pretty confusing problem with the MathExpression Block. As you can see in the Screenshot, the Block computes a different value than the exact same expression in the oml command window.
What's the reason for this?
Best Regards
Aiko
I guess you should use tanh(u1/u2) instead of tanh(u(1)/u(2))
Roberta
0 -
Thanks, it works now! /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Aiko
