I have a model which contains a linkage similar to a one sided universal joint. One half of the linkage is fixed while the other is coupled in all but one rotational degree of freedom. I am attempting to construct this particular part of the model using only beam elements but I am unfamiliar with the process of setting up the contstraints/geometry such that one DOF is not shared at the node of intersection. Can someone please run me through the steps?
Thanks!
